Re: 544 water pump leak
Posted by John G. Hasler on July 02, 2009 at 06:10:10 from (174.124.18.71):
In Reply to: 544 water pump leak posted by JerryinPa on July 02, 2009 at 05:51:04:
> I assume I should find another bolt and stick it
> in the hole behind the grommet?
No. That grommet and the passage it seals are part of the cooling system (in my opinion it's a kludgy design but it is what it is). Take it back apart, clean up all the surfaces (a bench top belt sander is great for the plate) and put it back together using a new grommet, new gaskets, and silicone.
