Re: 544 water pump leak
Posted by JerryinPa on July 02, 2009 at 15:55:09 from (75.198.38.251):
In Reply to: Re: 544 water pump leak posted by John G. Hasler on July 02, 2009 at 06:10:10:
Well, I took it all back apart and figured out that the hole with the grommet is a small bypass and goes all the way into the impeller cavity. Im figuring I didnt get enough gasket material smeared all the way around this hole and it leaked right there. I made new gaskets and used Form-a -gasket and got it all back together. Im gonna let it set up till morning then fill it and check for leaks. Hope it works!
