Re: Need help with non-start IH C-175 Gas motor
Posted by Brownie 450 on July 02, 2009 at 17:03:17 from (216.51.158.133):
In Reply to: Need help with non-start IH C-175 Gas motor posted by rebel70blue on July 02, 2009 at 16:07:21:
You'll have to check for #1 cylinder coming up on compression & then look at the timing pointer. #1 can be up on both the exh & compression stroke. You need it on compression TDC & then rotor should be pointing to #1 in the dist cap.
