The PTO on a 656 is probabaly the most sensitive part of that tractor. If the linkage has any play in it at all it will not work properly. The only way to adjust the PTO is with a hyd. gauge. This is obtained at fast idle.(full throttle)When you have the gauge on it you can see if the proper adjustment can be obtained. when the linkage pulls the plunger up, it must not let it fall down even the slightest when the linkage breaks over. If you can not adjust it then you have to pull the PTO out of the tractor and rebuild it. this is all covered in an IH service manual. Hope this will be of some help
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
