Posted by mattofvinings on July 04, 2009 at 14:09:25 from (67.142.161.30):
All, working on my spun rod bearing problem by prepping the tractor for a split.
One question I have is: how many bolts should I expect to remove at the bellhousing interface? There are 4 obvious bolts in the RH and LH rear cast "ears" of the block. It appears there might be a bolt or 2 up high under the gas tank and behind the steering-arm assembly but I am not certain. These are definitely smaller than the 4 big bolts above.
Also are there any hidden bolts ala the one that hides behind the starter motor on an H ?
I have the complete Binderbooks set but no info I can derive from that seems to answer these questions.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
