Re: Splitting a 340 utility
Posted by mattofvinings on July 05, 2009 at 12:51:26 from (67.142.161.30):
In Reply to: Splitting a 340 utility posted by mattofvinings on July 04, 2009 at 14:09:25:
Much as I'd like to get the two bolts without disturbing the steering, on this tractor, there's a cast "pocket" in the steering housing that envelopes one of the bolt heads more or less. There's clearance, to be sure, but I don't think a box end or open end would be able to get on it. The bolt is also bigger than I expected...guessing a 15/16" hex head.
Looks like the hood shroud has to come off, then fish out the gas tank, then the tank bracket, then finally the steering asm.
The previous owners also threw in a nice curveball, the steering wheel is welded to the shaft, as well as the three arms being welded to the hub. I am currently without a cutoff wheel to carefully slice thru the weld but I think the center console (which holds all the gages) can stay put for now...
These steering wheels must have been a weak link, my 460U is nearly a spitting image of weldment with the three arms also welded to the center flat disk/hub.
I am taking a few pictures as I go, will post these up later.
Thanks again for the replies.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
