Cranking problems on rebuilt H
Posted by SRH on July 05, 2009 at 18:26:36 from (207.200.116.5):
Hello I rebuilt my H> it has new sleeves,new dome pistons,rings> 6 volt positive ground,new wiring,new coil,new battery,new 2 gauge cables,new starter switch, all the connections are clean and tight. All that to say it will only turn over once on a new fully charged battery>if i am lucky it starts and runs great>if i miss that 1st try i have to push start it>and if i shut it down it won't trun over again> only have about two hours of run time on new rebuild.Any ideas? does it need to be broke in> too much compression? would apprecite any thoughts P.S the starter switch, Cables and coil are always warm after 1st try Thanks
