As the others have pointed out you need 2/0 cables with crimped and soldered (not clamped!) terminals.
If the engine still cranks slow with the heavier cables the component in the starter circuit that gets noticably warm while cranking is the problem.
Most likely culprits are the starter switch and the point where the ground cable bolts to the frame. However if the cranking circuit stays cool then it's the starter that needs attention.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
