Re: M Distributor Gets Wet
Posted by Jeff Z. on July 06, 2009 at 20:44:46 from (74.76.2.129):
In Reply to: M Distributor Gets Wet posted by WOK on July 06, 2009 at 20:34:01:
This may sound silly but if you can't put it inside put a tarp over the tractor.
I would check the transmission oil also from rain getting in through the shifter.
After the tractor has set not running for a few days open the transmission drain plug and see if any water comes out.
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo ... [Read Article]
