Re: M Distributor Gets Wet
Posted by Dr. Bert on July 06, 2009 at 21:31:43 from (72.36.57.58):
In Reply to: M Distributor Gets Wet posted by WOK on July 06, 2009 at 20:34:01:
WOK: I solved the same problem by wiping clear caulking comp'd around each seam or joint and when it dried it was hardly noticable. I've had no problems since. To keep water from getting into the transmission, I cut a 6X6 piece of inner tube,cut a small hole in the center and stretched it over the knob and down the shifter. Not attractive but effective,
