Posted by Jerry Deimerly on July 08, 2009 at 09:43:04 from (67.142.130.47):
I have a 1945 Farmall A that has a transmission problem and I’d like some ideas on exactly what I should look for and how to correct it. It seems to occur primarily in reverse. When I back it up it tends to growl initially and then it has a slight lurch as it backs up depending on the amount of incline. It has a slight growl when the clutch is released going forward but otherwise operates smoothly after that in all forward gears. The shift lever changes gears easily and other than a little whine going forward, it works great in all forward gears. While I don’t think this is part of this issue, I do keep the pto in gear because it slows the input shaft from turning so I can shift it easily. If I don’t have the pto engaged, it takes several seconds for it to be shifted without grinding gears. If anyone has experienced this with their Farmall A, I would appreciate any specifics on what the likely source of the problem may be. Thanks in advance, Jerry
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
