Re: Farmall A transmission question
Posted by Vic Bunn on July 08, 2009 at 21:02:41 from (4.255.70.217):
In Reply to: Farmall A transmission question posted by Jerry Deimerly on July 08, 2009 at 09:43:04:
I experience the same phenomenom as you when putting it in gear. It takes several seconds to get in gear after engaging the clutch. I haven"t tried the pto trick but will do so. Also, every bad throwout bearing I"ve experienced has been noisy until applying a slight pressure to the clutch, then it goes silent.
