Re: Wheel to Rim Clamp Bolts
Posted by Richard Fazio on July 09, 2009 at 11:13:37 from (65.213.90.98):
In Reply to: Re: Wheel to Rim Clamp Bolts posted by pete 23 on July 09, 2009 at 10:27:33:
Aren't the inner nuts thinner than a regular nut? I tried regular hex nuts and they were so thick I had no hope of clamping the rim. I was thinking of leaving them out and just putting some washers in there to take up the space and then using a regular nut on the outside. I think the reason for the inner nut is to just hold half of the clamp in place while your installing the other half. If you do 1 at a time it should be alright to leave out the inner nut?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
