Re: Wheel to Rim Clamp Bolts
Posted by LOU from WI on July 09, 2009 at 17:58:14 from (174.124.67.55):
In Reply to: Re: Wheel to Rim Clamp Bolts posted by Richard Fazio on July 09, 2009 at 11:13:37:
What we did on our 706 was use Grade 8 hex head fine thread bolts and bought some flat washers for the bolts, then we ground off two sides of the flat washer to fit between the clamps(as the square bolts used to) then tack welded very lightly the washers to the bolts with a mig welder.Then we reinstalled the bolts in the clamp that holds the cast iron housing to the rim ( about 15 bolts per side) and used the nyloc nuts to keep them tight.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
