Re: Wheel to Rim Clamp Bolts
Posted by D Slater on July 09, 2009 at 16:36:05 from (72.65.152.136):
In Reply to: Re: Wheel to Rim Clamp Bolts posted by pete 23 on July 09, 2009 at 10:27:33:
Pete, I never had much luck finding a standard bolt the right length with enough threads for the Jam nut and outer nut at the same time without going to a longer bolt and using washers under the head or cutting more threads. Did you find a standard one that will work? You can get new X heavy nuts that are 1-1/16 wrench size at bolt outlets, but the originals were 1 inch wrench size. Good Luck
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
