Re: Wheel to Rim Clamp Bolts
Posted by pete 23 on July 09, 2009 at 20:02:27 from (173.87.14.132):
In Reply to: Re: Wheel to Rim Clamp Bolts posted by D Slater on July 09, 2009 at 16:36:05:
I just cut a few more threads on a grade 5 bolt, and use a nice hard flat washer under outer nut using a 4 1/2 in bolt. Looks good. The jam nut doesn't have to be super torqued anyway so if those threads are less than perfect it will not have any effect on overall holding ability of the lugs as the outer nut is doing all the tensioning. Like I said though, I like the original nut as it takes a 1 inch wrench whereas all new std nuts take 15/16.I stay with nc threads also as they never gave much problem holding the wheels and are a whole lot easier to loosen in a few years down the road. I will add also that some use nc threaded bolts on the front rims also but that is not the way to go on them. Just my way I guesss.
