Re: Hey Brownie 450 or JimN....
Posted by Janicholson on July 09, 2009 at 19:38:38 from (64.61.211.190):
In Reply to: Hey Brownie 450 or JimN.... posted by Crazy Red Power in SE-WI on July 09, 2009 at 19:27:59:
The epoxy diode will do it. Make sure it conducts toward the alternator, and not the other way.
When the alternator is not turning, and the key is on, the #1 terminal appears to be a ground to the system. it is looking for 12 volts to excite (start) the charging. Once it starts charging, the #1 terminal puts out charging volts. This is what needs to be stopped. The diode needs to be at the alternator, in the line to #1 terminal only. If it is between the switch and the coil, it will not work. (put it 2 or three inches from the alternator, and put shrink tubing over it to keep it clean and dry. JimN
