governors
Posted by Dan in Ore on July 10, 2009 at 05:57:15 from (69.71.182.100):
Will a governor from a H fit on an M? If not will the internal parts interchange?
I got the M running yeserday and it does OK at idle about 750 RPM, but when I crack the throttle open it jumps to about 1950 RPM.
I took the cover off the governor and the "bellcrank" that the spring runs on is extremely sloppy on the shaft as if the hole is completely worn out.
My neighbor has a couple of parts H's, but no M's.
If not, maybe I can install a bushing in the original.
