Posted by rustyfarmall on July 10, 2009 at 06:38:06 from (209.152.78.140):
In Reply to: governors posted by Dan in Ore on July 10, 2009 at 05:57:15:
Either weld the worn holes shut and redrill, or install bushings. The spring should have just a little slack in it while at rest. Also, there is an adjustment screw inside that lets you set the RPMs to where ever you want it. The governors for the H and M will exchange but the throttle tubes are different lengths. H throttle tube needs to stay with the H.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
