Posted by NawlensGator on July 12, 2009 at 13:53:21 from (68.155.83.23):
After two minutes running up my driveway the tractor shut off as if someone turned the key off. Spark from coil was little to none. Power to the coil was OK. Wouldn't even hint of firing while cranking. Changed coil; No help. Swapped electromic ignition from a 140 that ran good and voilla, fired right up and ran great under load (mowing) for an hour.
This bad ignition is 2 or 3 yrs old. I found out it wasn't seated properly after about 1 1/2 yrs. Maybe I damaged it somehow. The good one is just as old and seems fine. I'll order a new one and also get a spare.
I haven't seen any reliability threads for these ignitions and thought I'd provide a data point. Would like to hear from anyone else who has had a problem, or how long they function before failing.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
