Re: Electronic ignition went KaPoot - IH 140
Posted by David G on July 12, 2009 at 19:39:45 from (216.203.121.248):
In Reply to: Electronic ignition went KaPoot - IH 140 posted by NawlensGator on July 12, 2009 at 13:53:21:
A lot of electronic ignitions release heat through correct mounting. I would check with the manufacturer and see if thermal grease should be applied to the device before mounting.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
