Posted by Farmallfarmer on July 12, 2009 at 19:05:19 from (216.195.147.20):
I'm in the middle of a complete engine overhaul on my '52 Farmall H, I put in all new sleeves and pistons and everything was working fine until I turned the crankshaft around to put on the last two connecting rod caps, and the #3 sleeve pushed up about halfway out of the block. I can push the sleeve back down in easily enough, but if I turn the crank around again the sleeve comes right back out. I've been told before that painting the outside of the sleeve with aluminum paint and sliding the sleeve back in and letting it sit over night will seal the sleeve up good,and keep it from sliding out again, but I wanted to make sure before I painted one of my sleeves that this was a good idea.
If this is a bad idea then I'd like other suggestions about how to keep the stubborn sleeve down in the block.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
