The correct way is to (I realize the issue) buy a sleeve designed for the hole tolerance. Some have used Iodine as a paint to literally rust the sleeve into the bore. If I were to make do, that is what I would do. It would be very rough on the next rebuild. Doing nothing will not be a good idea. The heat transfer is poor and the sleeve can crack at the top and be pulled down into the rods. Way uncool. If you send your sleeve to LA Sleeve, they will make a new one larger. Tell them the actual bore of the hole. IH made them in select fit sizes. Marked with letters on the block deck. near the cylinder. ABCD D was the largest. Kits tend to use only B size sleeves, but if one went in tough, that sleeve might do wonders in the big hole. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
