Re the system. It is not a good idea to run that wire that way. Use a test light, and put the lead to ground. Put the probe on the Positive battery post (should be light) Put the probe on the Starter relay where the battery connects (should be light!) Put the probe in the terminal on that post where the wire attaches that goes to the dash (fat 10ga wire but not a cable) (should be light) Put the probe on the other end of that wire at the amp gauge, wire terminal, not the amp gauge terminal bolt) (should be light) Put the probe on the terminal where that wire connects (should be light) Put the probe on the other amp gauge terminal, LOAD side. (should be light) Put the probe on the wire going to the Ignition switch at the amp gauge (should be light) Put the probe on the bat terminal of the ignition switch Should be light. (I'll bet this wire has a corroded terminal or bad connection) should be light. The reason your gauge is going nuts is that the whole system is now partially through the amp gauge, and part way through the extra wire. Clean every terminal and check every wire in the Probing path and you will find the issue. Do not use that wire (it was an OK bypass test, but not a solution at all. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
