Re: Farmall F-20 Carb Passage Plugs
Posted by clean John on July 17, 2009 at 18:19:00 from (216.228.193.194):
In Reply to: Farmall F-20 Carb Passage Plugs posted by Andy Motteberg on July 17, 2009 at 17:27:40:
Andy-- I will give you my way of removing these plugs- If they are over 3/16 " get a 3/32 drill bit --grind it on a wheel in reverse of what you see.Center punch the plug as near center as possible- Chuck the bit in a reversable drill . Go slow and make sure you stay in the center--You may want to start with a 16 pilot hole then use the reverse bit.Unless the plug is very tight the revese bit will screw it out --if not drill it to max then use a sqaure e-z out . Hope this helps .Others may use different methods. John
