Re: Farmall 450 LP ?
Posted by Albert Pereira on July 19, 2009 at 21:42:49 from (74.196.221.143):
In Reply to: Re: Farmall 450 LP ? posted by Owen Aaland on July 19, 2009 at 21:35:51:
I only start and run on vapor, I never open the liquid side. There is plenty of antifreeze. What would cause the coolant not to circulate through the converter/regulator. To check this do I just need to crack the line and see if coolant is flowing? Would a clogged LP filter cause this also? Thank you,
Albert
