Re: 656 draft control reassembly
Posted by John G. Hasler on July 20, 2009 at 05:02:45 from (174.124.18.71):
In Reply to: 656 draft control reassembly posted by karl f on July 19, 2009 at 21:42:46:
The trigger goes between the legs of the valve link in front of the pin if it"s like a 544 (which I think it is).
I have to do the same thing as soon as I get time and for the same reason: the draft control shaft is leaking. Again. And so is the draft control rod.
