656 draft control reassembly
Posted by karl f on July 19, 2009 at 21:42:46 from (172.162.26.135):
third party image
In the middle of repairing quadrant leaks and wish i had a camera...
I may need a few hints about reinstalling the lift cylinder when i get to the linkages. The part i am most unsure about is the trigger lever (the lever that tapers to a point). Not 100% sure whether it is forward of or behind the pin of the control valve (the only link pin you need to remove to remove the lift cylinder assembly). These parts are top middle of the open housing, to the left of the red cylinder in the attatched picture. I cannot see exactly what i need to in this picture, but a 504 looks pretty close to a 656 at this focal range.
Should be nearly leak free when i"m done!
thanks
karl f
ps thanks to charles todd for letting me "steal" your picture.
