1955 IH 300 utility hydraulics
Posted by Jkent on July 20, 2009 at 08:55:17 from (75.105.128.54):
My hydraulics quit working, pump made some nasty squealing noise before the hydraulics quit. I checked the fluid levels all fine and no leaks at any of the cylinders so did the pump go bad? I have pulled it off but is there a way to tell that the pump is really bad? New ones seem to be very pricey and I don't want to replace it if its not the cause of the problem.
