Re: 1955 IH 300 utility hydraulics
Posted by mattofvinings on July 20, 2009 at 11:37:18 from (67.142.161.33):
In Reply to: 1955 IH 300 utility hydraulics posted by Jkent on July 20, 2009 at 08:55:17:
My thoughts are that if you can turn the pump's input shaft over by hand with the pressure line disconnected that is the first good sign.
Next good sign is that by doing above you are starting to pour out a little fluid from the pressure port as a hyd pump is positive displacement even if turned over slowly.
If above checks OK I would reconnect to tractor power and install a pressure gage on the pressure line to see what you are actually getting. It is also prudent to make sure the pump is not somehow blocked on the suction side, either via clogged filter or screen, etc.
This post was edited by mattofvinings at 11:39:09 07/20/09.
