Farmall H - Heisler Live Pto
Posted by keddano on July 20, 2009 at 10:46:10 from (65.103.54.218):
third party image
Picked up a non running H at a auction a few weeks back. Mainly because it had the Heisler Live PTO unit on it.(Needed a tractor to bale 4 acres with)
Spent the last few weeks removing 60 years of oil,grease and dirt from it.After cleaning points,doing a compression check...115#,115#,120#,115#. Fired it up yesterday. Everything seems get and works fine.
Now to the question. What do you guys know about these? The pto will run fine. But not sure if the Heisler unit is working properly. It will run the PTO with the clutch pushed in.It seems to work like a hand clutch on a Deere. When the handle is in the backwards position the tractor stops Pto runs,Push forward and tractor moves with PTO running. But it doesn"t seem to Snap into a positve locked position. Maybe a detent that is sticking? Any info or related documents would be appecerated. Thanks
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
