Re: Farmall H - Heisler Live Pto
Posted by Janicholson on July 20, 2009 at 16:59:19 from (64.61.212.160):
In Reply to: Farmall H - Heisler Live Pto posted by keddano on July 20, 2009 at 10:46:10:
The PTO will not provide power with the main clutch pushed in. It will if the Heisler lever is in either position.
The Heisler unit is a high capacity friction clutch, that is disconnecting one set of final drive pinion/Bull gears. This is the same as having a steering clutch in a dozer, except this has a differential and when one side is disconnected, the internal gears act like that wheel is on ice, and the other wheel does nothing.
Thus the tractor stops, and the trans keeps going.
powering the PTO shaft.
It is still necessary to use the main clutch to shift gears, as all internal gears will turn and grind if the main clutch is not pushed in when shifting. JimN
