Posted by Janicholson on July 20, 2009 at 16:48:50 from (64.61.212.160):
In Reply to: Re: Farmall M clutch posted by jeff338 on July 20, 2009 at 13:42:04:
One item that needs discussed. If the old disk was worn out, the new disk will compress the springs radically. Your description of the driven disk as being in with the spring plate To the rear to clear the Flywheel bolts is correct. If the three bolts in the pressure plate were installed to compress the springs, the disk will float free. If they are released (when the other three are nice and tight) the finger levers should move out some, but no where near as far as before This is evidence of a much fatter driven disk (perfectly normal) JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
