Re: Farmall M clutch
Posted by jeff338 on July 20, 2009 at 13:42:04 from (162.57.2.162):
In Reply to: Re: Farmall M clutch posted by ScottyHOMEy on July 20, 2009 at 13:11:46:
Thanks for the help. I did not do any adjusting to the fingers as you described so I will take the clutch assy. back out and do that.
I agree that it seems like the plate was put in backwards but I don't think so. I believe the long part of the center piece is toward the transmission which should be correct.
I will post when I have it fixed. It may be a day or two before I get to it. Thanks again.
