Posted by Owen Aaland on July 20, 2009 at 18:28:14 from (65.174.247.87):
In Reply to: Farmall 450 LP ? posted by Albert Pereira on July 19, 2009 at 20:13:15:
The hoses going into and out of the converter should both be warm along with the converter. Hoses that stay cool would indicate loss of coolant flow.
How much fuel do you have on the tank? Does the bottom of the tank get cold? When you are running on vapor the tank becomes the converter, changing the liquid propane to vapor. As the tank cools from you drawing off vapor, the pressure inside the tank will drop. Once the engine has been running a few minutes you need to open the liquid valve. That will allow the engine heat to covert the LP rather than depending on the fuel tank to do the job. You may be running too lean as the pressure drops in the tank.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
