Posted by Albert Pereira on July 20, 2009 at 19:20:08 from (74.196.221.143):
In Reply to: Re: Farmall 450 LP ? posted by Owen Aaland on July 20, 2009 at 18:28:14:
I pulled the drain plug on the bottom of the converter and antifreeze was present. The vapor fuel lines stay cool not cold. The converter also stays cool not cold. Checked the filter looks fine. Started it on vapor then switched to liquid made no difference on run time. Tank does not get cold just cool at the lower level where the fuel level is. Tractor ran fine before just started doing this recently. I haven"t messed with any adjustments. Usually it runs strong all the way tell empty. But last few time I thought it was out of fuel it only took about 15 gallons. it dies out like its running out of fuel. How hard would it be to convert to Gas? Is it just a tank and carb change out?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
