Posted by ScottyHOMEy on July 21, 2009 at 13:52:44 from (70.105.242.214):
In Reply to: Re: Farmall M clutch posted by jeff338 on July 21, 2009 at 08:03:02:
Check out Owen's idea up at the top of the thread about the linkage first. It's been so long since I got up into the belly of an M that I'n not even sure what washers he refers to, but you've got the tractor there. Find them and check it out.
This gets back to the finger adjustment thing. As Jim N pointed out just above, a clutch disc wears, the fingers move to the rear reducing freeplay. Normally you take care of this by adjusting the linkage. If it could (not sure it can and still function) wear to the point that they couldn't adjust the linkage any further, it's possible someone did some tinkering on the fingers to get some freeplay back, which would produce the eymptoms you're having.
You've obviously had parts of the linkage apart so it would bear a second and third look, front to back. If you're satisfied that it's in good order, then it may be time to get the cover up onto a bench and check it out. If it's anywhere near the specs I gave, leave it alone, it's not the problem. If it's not you can try to adjust it as I described or take it to a machine shop with the specs and have them do it for you (shouldn't be TOO costly).
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
