Re: Farmall M clutch
Posted by jeff338 on July 21, 2009 at 08:03:02 from (162.57.2.162):
In Reply to: Re: Farmall M clutch posted by ScottyHOMEy on July 20, 2009 at 14:37:13:
Both of the last two comments make sense. The old clutch plate was basically gone. Worn down to metal so there was a large difference in thickness between the old and new. However, the 3 spring loaded levers are so flat that the mechanism that depresses them will not reach them (even with the rod disconnected from the pedal). The clutch release mechanism movement bottoms out before it gets to the 3 spring loaded levers. The three bolts are not in the middle holes that are for depressing the springs and let's assume that I have not installed the clutch plate backwards (which I am 99% sure of). What else might be wrong? Is it possible someone else made some modifications in order to allow the clutch to work with a worn out plate? I have seen my current problem posted before but not the fix. Any more ideas?
