Posted by Janicholson on July 21, 2009 at 18:24:48 from (64.61.212.178):
In Reply to: Re: Farmall M clutch posted by jeff338 on July 21, 2009 at 08:03:02:
Because the system is still accessible, I would probably take out the three bolts and install them in the three holes. If they in deed do the release thing, I would then spin the input shaft to see if there were interference with the F/W bolts. If it is smooth, and the bolts move the lever about 1/2 to 5/8" farther than the "flat" you indicate, I would believe the clutch and PP are OK. People have done two unfortunate things (really more, but these are common) to clutches. One is to cut the linkage shorter when the adjustment runs out, and the other is to cut the mounting surface of the FW to allow the disk to be pinched harder. This requires removing the F/W (a split) so would be more intense than a new disk. It could also have been machined wrong. I do not know the step depth of the F/W, but it is available, and easy to measure. On most new installations the fingers are almost always near flat when installed. JimN
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
