When i looked at my 656, the rear drain pipe drops straight down to nothing. The oil stream pretty much goes down between the bull gears and behind the differential--a wide open space! removing the bull plug in the front of the housing would be slightly more beneficial to the left side of the differential but not enough to really matter.
i looked at the caseih parts site on the 2606 and can tell you that the only way you could remove the drain pipe plate would be either through the pto opening or by removing the draft housing. at least the lower link sensing models give you an access hole above the pto because of the 3rd link mount. But, for you a sawzall sounds easier!
tomorrow night will be the beginning of running my tractor with the modification. soon as i install the hyd pump gear (pto driven shaft bearing went out taking the gears with it...was a good time to do all the little things while waiting for major parts). Between new gaskets, seals, and o-rings; along with the standpipe modification, the top end of the tractor should be leak free for a good time.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
