Farmall 706 starting issues
Posted by r0ckman20 on July 24, 2009 at 11:40:51 from (96.18.62.251):
We have a Farmall 706 gas that we are having some starting issues on. We have replaced the starter and solenoid, a new key switch has been installed, a new starter button has been installed on the dash, brand new battery has been installed, and the clutch safety sensor has been bypassed.
What happens is the tractor won't start. Usually this occures when it is hot. It won't even turn it over. You turn the key, hit the button, and sometimes it will click and sometimes it will do nothing. When it does click, it acts like a dead battery. However, if you take a screwdriver and cross the starter, it'll spin like nothing and fire right up.
So there is something between the dash and the starter. We have already done the above, does anyone have any other suggestions? Does the starter wiring go through the light switch assembly as well? We've noticed that switch may need to be replaced also because of years of corrosion. Just curious if you guys have any suggestions.
