Re: Farmall 706 starting issues
Posted by Janicholson on July 24, 2009 at 13:09:17 from (199.17.55.131):
In Reply to: Farmall 706 starting issues posted by r0ckman20 on July 24, 2009 at 11:40:51:
I agree with the Vet. Clean the connections. If still intermittant, the following test will determine the repair. Put it in neutral,lock brakes.
pull (or unbolt) the start terminal (small) that connects to the push button. Now use a jumper to connect the cable terminal from the bat, to that terminal. If it cranks correctly the wire, or button circuit is faulty. If it is still flaky or does not work, jump across the bat cable to the starter motor input connector. Heavy current, jumper cable, or better. If it now spins, it is the relay/solenoid. JimN
