Re: Farmall M Electrical Issues
Posted by Tom 43 on July 25, 2009 at 03:08:50 from (70.142.52.237):
In Reply to: Farmall M Electrical Issues posted by Braxton on July 25, 2009 at 02:30:13:
The problem is that you are running a 6 volt coil with a 12 volt battery without a ballast resistor. If you are going to use a 12 volt battery you have two options: 1) A 6 volt coil with a ballast resistor or 2) A 12 volt coil without a resistor.
