Farmall M Electrical Issues
Posted by Braxton on July 25, 2009 at 02:30:13 from (68.88.168.47):
We've had this 47 Farmall M for 20 years. It ran perfect until this year. The tractor does have the original 6 volt system I assume but without the generator and any lights. We run it with a 12 volt battery. As a result of some electrical issues, we replaced everything. It got a new starter, ignition switch, starter switch, battery cables, points, condenser, rotor, plug wires, coil, and new wiring. Ran great for a while until the coil went bad. Was very, very hot to the touch. Put the original coil back on and it ran fine again. Now it won't run yet again and the coil appears bad. I figure I must of rewired the system wrong.
My question is: What would the wiring schematic be for a 6 volt system running a 12v battery without a generator. Thanks guys.
