Re: Farmall M Electrical Issues
Posted by Dave S. on July 25, 2009 at 05:23:32 from (208.92.170.53):
In Reply to: Farmall M Electrical Issues posted by Braxton on July 25, 2009 at 02:30:13:
Get a 12 volt coil (make sure it is a 12 volt coil to be used without a ballast resistor, it should be printed on the coil) and hook the wire from the - side of coil to the distributor if you have negative ground.
Using the 12 volt coil with internal resistor will eliminate the external resistor and one more thing to go wrong.
