B-275 differential transmission rebuild
Posted by ccaissie on July 26, 2009 at 05:46:47 from (70.16.96.100):
Hi:
Have decided to replace the cracked case on my B-275. I have access to a used case and would like input on this procedure before I begin.
I have the manual sold through YTD which I used to do an in frame overhaul.
Shouldn't be any harder than rebuilding a triple countershaft Mack, but maybe there are shortcuts, hints and caveats from those who have actually been inside one.
What parts may be required, which ones should be replaced while I'm in there?
Any info will be greatly appreciated.
regards,
Colin
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
