Posted by Wayne Wiseman on July 26, 2009 at 11:32:32 from (67.72.98.45):
I have a 1928 McCormick Deering 10-20 and the gas leaks at the stem of the gas shut off. I tightened the packing nut but the nut is in as far as it can go. Hope someone can help. If I can't stop the leak is it possible to buy a new sediment bulb. It has two tanks, one large for keresone and a small tank for gasoline starting.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
