Re: Gas shut off stem leaking on McCormick Deering 10-20
Posted by Dr. Bert on July 26, 2009 at 15:57:47 from (72.36.57.58):
In Reply to: Gas shut off stem leaking on McCormick Deering 10-20 posted by Wayne Wiseman on July 26, 2009 at 11:32:32:
Wayne: You might want to try this. Drain the gas from the tank, Loosen the packing nut and back out the shutoff until you can see the shaft. Then wind a few wraps of water faucet packing material (a graphite coated cord-available at a hardware store) Screw the shutoff back in a ways and replace the nut. Be sure to turn in the shutoff as you tighten the nut.
