Posted by Szrachnor on July 26, 2009 at 19:34:41 from (68.118.187.9):
In Reply to: IH B414 PTO Grinding posted by Cwt32286 on July 26, 2009 at 19:08:51:
If it's a dual clutch the pressure plate splines or the PTO shaft splines could be worn out. You can check this out through the 4 bolt hand hole cover under the clutch housing. Otherwise the splined coupling that actually engages the PTO to the rear shaft may be worn out and need replacing.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
