Posted by jdemaris on July 27, 2009 at 05:42:37 from (67.142.130.16):
In Reply to: IH B414 PTO Grinding posted by Cwt32286 on July 26, 2009 at 19:08:51:
That's very common in B275s and B414s. If, one engaged, your PTO the dual clutch, the PTO clutch often drags, or gets stuck engaged altogether. Also, the mechanical PTO linkage gets wear.
When the PTO is engaged, does it stop when you push the clutch pedal all the way in? If not, the PTO clutch is stuck. I've got one B414 I've been using for many years like that. To engage the PTO, I throttle it down and turn the engine off while holding slight pressure on the PTO lever. When the engine is almost off, it slides in fine - and I then let it come back to life, or restart to use the PTO.
All my B275s and B414s have done this, one time or another. I've pulled a few apart (split), took the clutches apart and fixed. Then, a few years later, it would happen all over again. So now, I just use as-is. Still works a heck of a lot better than a tractor without live power.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
